SK.. in Frozen Cold Western Canada | Here ya go.. I think.. Small and Cheap seemingly ~~ a 32M SanDisk looks like it would be under $20.00 Shipped!! And the Description of MMC vs. SD Compatibility below as well :
http://www.memoryxflash.com/multimediacard.html
Toll Free : 1-866-636-6799 (1-866-MemoryX)
>> MMC is about the size of a postage stamp: 24 mm x 32 mm x 1.4 mm. It is slightly thinner than an SD Card and can be used in most the same applications. MMC uses a 1-bit serial interface, but the newer MMC plus allows transfers of 4 or sometimes even 8 bits at a time. The slightly thinner, pin-compatible MMC cards can be used in almost any device that supports SD cards if the software/firmware on the devices support them. |
