SWMN | go to dieselplace.com and do a search. will tell you what to do. Its a easy fix and cheap. takes about 5 min to pull it out and about 15 to fix it. Need to pull it out and then pull apart. it will ruin a couple of the grooves but then can be fixed back up with a file. I then coated it with red rvt silicon and reassembled. leave it overnight and it will more than likely be fixed. the bearing on the bottom of the column can be a issue too but a hose clamp or muffler clamp can fix that too. just a plastic bearing that gets loose | |
