Posted 10/24/2010 22:32 (#1406401 - in reply to #1406375) Subject: Re: Pro 600 issue
roaming
it's normal. You've reached the Task size limit. The acre count that it's clearing is the area of the Task. You can still see the Field Area in Performance > Sum1/Sum2. Or you can put a manual Area Counter on any Run screen and reset it whenever you want.
