| Using FMX with Nav 2 on 2388 combine. Have gone through Calibration screen and combine will follow the AB line but as you turn around to make a new pass the bean head is always running close to the beans on the left and the next pass will have more room to the right. If I turn back on the last pass the tire tracks will be on top of each other. Antenna is centered on machine. Can use the nudge but if it is working right don't think this would be needed. Pretty new to this type of equipment so any suggestions would be helpful. Think the auto steer is working fine just need to get the line centered with the bean head. | |
