Parsons Kansas | I just drilled a hole in the bucket in the center for the big bit. Then drilled two holes off to each side for bolts. It's not a bearing holder just took a piece of 1" stainless steel pipe and welded it to a piece of stainless steel scrap and drilled 2 holes to mount it in the bottom of my bucket. Used some stainless steel carriage bolts and nuts to bolt it all together. Bolted it to a 1x4 board I had. | |
