Posted 10/9/2010 20:17 (#1389435 - in reply to #1389427) Subject: Re: ez steer bridge fault
ensure that you have the ez steer system connected direct to the battery via a switch or relay if you havent a heavy enough switch, i cut all the lighter plugs off them as they go out to prevent all sorts of problems like this.
what screen, what firmware is it on? what firmware is in the ez steer controller?
