Seymour, IL | just went through this, MikeSEIL is right on...check the engine rpm on display when seperator quits. (head won't work either). It was the RPM sensor, mounted on bottom of hydraulic drive on bottom LH side of pulley. When you look up you will see notches cut in the outside of the pulley.
Sensor was 63 from CaseIH (Sunday at noon, wasn't going to argue :))
2 minutes to change out, and no problems since. May be easier to change now than wait for the problem to re-appear.
hope this
bryon | |
