Classifieds
1440 cable height problems. seeps down.
Machinery Talk
strokerace
10/5/2010 20:22 (#1385141 - in reply to #1383936)
Re: 1440 cable height problems. seeps down.
maybe the issue is the accumulator then because if i
"Set height knob in cab to book recommendation.
Start for floating A open B- always open C always closed.
Raise head and hold to max load accumulator. Stop and close A.
Put hyd lever in float position. Crack A open and lower until cable tensions on hyd pin, close A.
(pratice for what you want
if i raise the head it wont lower again.
strokerace
: 10/4/2010 14:43
RE: 1440 cable height problems. seeps down.
Oilfarmer
: 10/4/2010 22:09
strokerace
: 10/5/2010 20:22
Oilfarmer
: 10/6/2010 07:00
strokerace
: 10/6/2010 20:41
