Posted 9/29/2010 00:30 (#1377924 - in reply to #1377909) Subject: Re: Will this work? Bin Unloading Question.
Winkler, Manitoba Canada
I would likely go with your idea as well. As long as the auger extension is built heavy enough to transmit the power required for the sweep it should work. I have a 7 1/2 h.p. motor on an 8" unload with a powersweep in a 33' bin. You probably will need more than 10 h.p. to run that length of auger with a sweep if you want to run the auger full with a standard rpm.
