Posted 9/28/2010 09:31 (#1377096 - in reply to #1376540) Subject: Re: JD 8120 hydraulic overheating
It is showing maybe 200 degrees when the light comes on and if you keep running it will hit 220. I might check the rear end case with an infrared thermometer and just double check the sensor. The lines and hydraulic motor get so hot you sure can't touch em but haven't felt the tractor. Thanks to all!
