northern ny, | does the solenoid activate or not . there is a 3 wire plug going to it i have had the wires just bout a foot away from engine rub threw. thus not letting it start i believe they are white in color with red . if it activates then you have a fuel issue try changing the return line fitting in pump it has a check valve in it . may not be setting all the way. does it have a hand pump also . if so it could be the valve in it has fallen out seen that before on the magnums. some thing to ck out 4 u | |
