SE VA | Our White 2-155 with 3800 orginal hours has developed a problem with getting air in the fuel. It will run good for about 10 minutes and then it is short on power and misses bad at high rpms. Sometimes it gets so bad it will actually cut off. There is a lot of bubbles in the top of the two fuel filters. After it sits overnite the bubbles in the filters are gone. I have checked all the lines and can't find anywhere it could suck air. The hoses have been replaced and in good shape. I am just wondering if anyone knows a common place these Whites will suck air from or had a common problem. Thanks. | |
