Posted 9/9/2010 20:42 (#1353179 - in reply to #1353153) Subject: Re: JD 7820 IVT Stuck in Park
NESD
Disconnect the fuel transfer pump on the primary fuel filter and see if the tractor will move some before the engine stalls from lack of fuel, if it does the transfer pump is failing and causing electrical interference that is affecting the park brake circuit.
