Earth | Yeah, it seems there might be a problem with headlands in v4.10. There are 2 ways you can work around it:
1) Go back to v4.0; or
2) Change the View option (under Lightbar->Display Config) to Manual & make sure that when you start your headland you are in plan view (ie: looking down on the tractor icon).
The problem you have seen only happens if the view auto switches from plan to perspective when you press OK to start the headland. So putting it in Manual view mode will stop it happening. | |
