Somerville, Indiana | The electronic people at Ag Express have a deal like that Rich. Can wire to use with planter monitor last time we considered it. Have since counted seed on a test run on hard ground with openers just touching mother earth. Then watched the acres with the wonderous Magnum acre counter. Good idea to try for 5 acres left, maybe more if weight is needed for proper depth. By the way, the seed runs on the end run out before the others because the seed only comes from one side of the opening, all others feed from 2 sides. Just a little Hoosier Knowledge for the less privileged. LOL
Have you been faithfully combing Flicka or have you passed that job on to your daughter? | |
