Here is an update of the corn that was planted on May 5th into spring wheat stubble. The first and second photos is of the corn planted into a bare spot, it is 81 inches tall has 18 leaf collars,has tasseled and the milk line is 1/4 down the kernel and has acumulated 1954 gdd`s. The third and fourth photos shows the corn planted into a 10 inch wide strip cleared of residue it has reached a height of 94 inches, has 18 leaf collars, milk line 1/4 down the kernel has acumulated 1908 gdd`s. I have switched to using the air temperature to figuring gdd`s starting on 6/24 on this test. The fifth and sixth pictures shows an ear from a plant that was planted into a 10 inch wide cleared strip that is a different hybrid, the milk line is 1/4 of way down on the kernels. By the way the sensor at 6 ft is in the corn canopy. The depth of the kernels from tip to crown is .5 inches. forgot to meaure width.
spring wheat stubble | | | | min | max | | |
| | | | | 2 inch | 2 inch | | |
| | | min | max | soil | soil | | |
| min | max | 2 inch | 2 inch | spring | spring | | |
| air temp. | air temp. | soil | soil | wheat | wheat | | |
| 6 ft | 6 ft | spring | spring | 10 inch | 10 inch | min | max |
| above | above | wheat | wheat | cleared | cleared | 2 inch | 2 inch |
| ground | ground | residue | residue | strip | strip | bare soil | bare soil |
date | (*F) | (*F) | (*F) | (*F) | (*F) | (*F) | (*F) | (*F) |
08/15/2010 | 49.67 | 79.41 | 64.91 | 73.15 | 64.22 | 69.02 | 63.54 | 67.65 |
08/16/2010 | 49.67 | 80.12 | 63.54 | 83.67 | 62.17 | 69.02 | 61.48 | 67.65 |
08/17/2010 | 47.53 | 85.1 | 59.42 | 80.12 | 59.42 | 69.02 | 59.42 | 68.33 |
08/18/2010 | 61.48 | 88.01 | 66.96 | 74.53 | 64.91 | 70.39 | 64.91 | 70.39 |
08/19/2010 | 64.91 | 81.53 | 69.71 | 72.46 | 67.65 | 70.39 | 67.65 | 70.39 |
08/20/2010 | 64.22 | 86.55 | 69.02 | 88.01 | 67.65 | 72.46 | 67.65 | 72.46 |
