Southern Illinois | set the freeplay atleast to 2" both ways, angle per turn 8-10, aggressiveness 90-100, make sure the wheel base is measured correctly from the pivot, and the antenna offset is correct. when you are calibrating you can push the ? for help and a better description of what info it needs. Some of the offsets and wheel bases are confusing and this helps clear them up. hope this helps. You can also push help when you set angle per turn and it will tell you that aggressive weaving means the angle is to high, and slow weaves it is to low (I think, I haven't done one of these in a year or so). | |
