Pontiac IL | How steep are you going to be? 22 degrees is about as far as you can go with dry corn, it wants to roll back no matter how wide a belt. A 15" belt will compare to a 10" auger and a 20" belt compares to a 13" auger, at least the company I sell for. I use a 35' 15" with a low profile hopper to load 66" side hoppers with no problem, dump trailers or high side hoppers would be a problem, probably would want at least a 45' belt. | |
