Posted 8/7/2010 20:14 (#1305328 - in reply to #1305309) Subject: RE: STS combine help needed
Southeast Iowa
To help your sanity you can shut off the buzzer. Hold the hydro handle in the neutral position, but pulled to the right. while holding the lever over turn the key switch to crank then back to run. it should keep the buzzer off until the key is shut off again.
