| The wiring harness is in the front of the cab. There should be a rubber grommet by the windshield wiper on the left side (standing on feeder house facing combine). Also you will have to remove the light closes to the windshield wiper on the left side to access the harness and to cut a hole in the grommet. Then Deere makes a bracket to mount the receiver in front of the cab(part # AH211594). As far as to mount the GS2 in the cab I use part # AZ103900. Look at this post for ideas on GS2 bracket.
http://talk.newagtalk.com/forums/thread-view.asp?tid=173954&posts=1... | |
