Posted 8/1/2010 10:55 (#1296284 - in reply to #1296059) Subject: RE: Baler pressure problemss
Embarrass WI
Every time that has happened to me it was because I had the hydraulic hoses hooked up backwards.
Try going through the procedure to release the pressure and start over.
Do you have the baler on a different tractor than you used before? The baler valve has to be set up for open or closed center system, set up for one won't work on the other.
