Posted 7/1/2010 08:04 (#1256790 - in reply to #1256269) Subject: RE: HID kits for 2366, mx120
On the combine the inside two lights use a standard 9004 bulb and will be easy to convert. The outside two lights on the top of the cab are an odd ball bulb and you will have to change the housings to go HID on them. I converted our 2377 last fall and posted pictures and part numbers on here, you should be able to find the post if you search for it.
