| you can do similar to what highline is saying, but you can let the blind lead the blind so to speak. Use the rate controler to turn on and off relays which do the switching in the cap, so the relay will replace the origional switch. Then when the rate controler tells it to shut off a boom it would be doing the same as if you reached over and flipped the switch yourself. The only trouble with this is, I am not sure about your spracoupe, it would have to have switches remote mounted or else you probably wouldn't want to do this. I had helped a guy get a system like this going on a Case sprayer he left the raven and the aim command and all factory equipment in for rate control and just used the Rate Controler for swath control. | |
