just a tish NE of central ND | Schucks...... there have been a lot of those motors successfully re-sleeved. And parts aren't even badly priced unless we start talking about the cam and lifters.Piston and sleeve kits are reasonable for them.Either way, you might as well take it apart and check it out because it wont stop leaking by itself and you are out almost no $ to take it apart and look.
Take a good look at the oil/ water cooler if it has one.That might be where you leak is at. |
