Posted 7/6/2010 11:02 (#1262445 - in reply to #1257169) Subject: Re: outback S3 in Hagie 2100
it depends on what software you have in the s3 if it has anything less than 1.96 then use 0 if higher put in actual value. When calibrating tilt make sure you are on a flat surface and box is level front to back and side to side.
