Winkler, Manitoba Canada | 8560 MF was the first in that series of machine. Not quite finished and underpowered with the small cummins. TR97 with 5000 hours would be tired unless maintenance was top notch. Rotor covers/dividers would likely have been changed several times. Rear cage would likely have been done as well. Pretty hard to see what shape things are really in without pulling rotors. You can get a good idea however, with a trouble light and mirror, looking through the concave extension module doors. I run a 6 row head on a 99 and it works okay. Depending on conditions the 25' flex would seem small. I would not rate the TR as easier on straw. | |
