Posted 7/6/2010 13:37 (#1262577 - in reply to #1255003) Subject: Re: How is the Matrix/Fieldpilot performing?
IL
We use the Matrix FieldPilot on a JD8300 to plant split row beans and it works quite well; right now just using WAAS and the turn into the next line is as expected for the application. The valve is PWM; through the Matrix there are several adjustments available to tweak while on the fly. The 4x30 series are not supported with a released hydraulic kit.
