Here is an update of the corn that was planted on May 5th into spring wheat stubble. The first photo is of the corn planted into a bare spot, it is 36 inches tall has ? leaf collars, and has acumulated 795 gdd`s. The second photo shows the corn planted into a 10 inch wide strip cleared of residue it has reached a height of 30 inches, has ? leaf collars and has acumulated 748 gdd`s. I have switched to using the air temperature to figuring gdd`s starting on 6/24 on this test. The reason for the ? in the leaf collars is because of some confusion on my part.
spring wheat stubble | | | | min | max | | |
| | | | | 2 inch | 2 inch | | |
| | | min | max | soil | soil | | |
| | | 2 inch | 2 inch | spring | spring | | |
| min | max | soil | soil | wheat | wheat | | |
| air temp. | air temp. | spring | spring | 10 inch | 10 inch | min | max |
| 6 ft above | 6 ft above | wheat | wheat | cleared | cleared | 2 inch | 2 inch |
| ground | ground | residue | residue | strip | strip | bare soil | bare soil |
date | (*F) | (*F) | (*F) | (*F) | (*F) | (*F) | (*F) | (*F) |
06/24/2010 | 52.49 | 80.12 | 65.59 | 75.92 | 64.22 | 75.92 | 62.17 | 73.15 |
06/25/2010 | 66.96 | 89.48 | 68.33 | 76.62 | 67.65 | 76.62 | 66.96 | 76.62 |
06/26/2010 | 62.85 | 78.01 | 69.71 | 73.84 | 68.33 | 73.84 | 68.33 | 73.84 |
06/27/2010 | 58.04 | 83.67 | 67.65 | 77.31 | 66.28 | 76.62 | 66.28 | 74.53 |
