Posted 6/26/2010 23:35 (#1251887 - in reply to #1251676) Subject: Re: Moldboard plow and autopilot settings/measurements?
N IL
On 15 acres you will not do much plowing with the autopilot. I have made it work but it really only works best in big, flat, square fields.
About the best thing to do is adjust everything that your plow is running perfectly square behind the tractor. Starting lands will be the tricky part but you will figure it out pretty fast.
