| Are you running autosteer on the x15 or just guidance? If you have steering you will have to make sure you have configured Procal, which can be found on the desktop. In procal, press change/view config. There you can set the GPS port to com 1, and if you press config tab along the top you will have to have a .dll file selected. Do not select "wheelie.dll" but something like 34.##.##. The numbers will not matter. Then press done, then close. In the guidance screen (the green map screen) press general setup and set the gps port to "none" and the baud rate to 19200. If you are not using Steering select Com 1 here and do not setup procal. Hope this helps. | |
