South Central Nebraska | I have a 1254 with a fast-close pump and air controlled booms. I got my harness from ag express. I hooked everything up as instructed on Ag Talk. I can run my pump, but the Rate controller won't run my boom sections. I used the three wire setting. I tried the two wire and got an excessive voltage warning and it still didn't work. I can run my boom sections with the rogator master/section switches. When i run the switches with the rogator controls there is no indication on the rate controller.
I used the valve cal written on my valve, 743. My only option for meter cal units was "gal" so i divided by 10 and used 137. Is that correct. This is not important unless i get the sections to work, but may save me a post later. | |
