| While running the greenseeker has anyone had any trouble with the Nomad not talking to the rate controller? I have a Raven 750 and a Nomad running the GreenSeeker and I can't get the two of them to talk to each other? When I go into my status is says Rate Controller: Response: NO? I've checked all my cables and everything seems to be correct. I have a null modem that I'm going to try later and see if that helps? If you have any feedback whatsoever on how to setup the Raven 750/Nomad any would be helpfull! Also with the raven how do you setup the product 1 so that it defaults to the Nomad? I'm guessing if I get the two of them to talk to one another this won't be an issue, but was just checking.
THANKS!! | |
