Posted 10/25/2011 12:36 (#2018979 - in reply to #1237277) Subject: Re: Top dressing for high protein wheat.... what works for you?
Rolla, ND
Liquid urea is a good choice for postanthesis work. Probably don't need to dilute it with more water, but more water wouldn't hurt. 5 gallons of liquid urea is a bit on the light side. Way more than a gallon of Coron mind you and enough to see results but if protein is worth the trip, then the optimum rate is probably higher.
