Idaho | I read somewhere about putting an agleader insight in a new 7120 combine, I was wondering if I have the insight with autopilot unlock already and a nav 2 controller with a 252 waas antenna can I put it in a pre wired 7120 that comes with a pro 600, and a case nav 2 not trimble. In your opinion would I be better off using the pro600 for steering and yield monitoring, or putting in my system and ordering the combine without the pro600. I do use two other insights for yield mapping in older combines, so for combining maps that would probably be easier. Also trying to figure out which option will be most cost effective, I am sure the cabling isn't cheap for the steering and yield monitoring system. | |
