Posted 6/6/2010 01:18 (#1226148 - in reply to #1226004) Subject: RE: 9760 died while roading, any help.
Will it run on ether for a little bit and then die? Had one that would do that and had similar code. Pull lines off top of high pressure pump that go to the common rail, stand back a little and crank the engine and see if you get any fuel out of it.....if not probably bad pump if you have fuel up to it.
