| I can't beleive how much thay charge for those things. I've got mine all planned out in my head. Make a frame out of square tube to hold 6 boxes. Make shoots to flow the seed into a brush auger running under the middle to bring the seed to the front. Than run that auger into a "vertical" brush auger. Run the whole thing with a Honda motor hyd pump. Also want to put cylinders on the vertical auger to fold it and change the angle. I already have the augers I need kicking around. A couple grand in steel and a couple weeks work...only problem is the time. | |
