SE MN | We have a pull type sprayer and just got swath control through Ag Leader this year. The sprayer has a hyd. pump and all the the nozzles are non-drip triple bodies. The tips engage around 18 psi. In order to get enough pressure you have to be going a certain speed, which is at least 8 mph, so you always have to put it in manual to get enough pressure when you start out. So my first question is, is there any way to make the pressure run off something else besides speed? My other question has to do with the gps, everytime I shut the gps unit off it resets the Manual rate back to 8 gpa., is there any way to get it to default to a higher rate? | |
