Posted 5/30/2010 19:27 (#1218941 - in reply to #1218841) Subject: Re: Fuel pump or carb?
Walnut Grove MN USA
had a similar problem with a Farmall 350. Would run for an hour or so then start losing power. Shut it off for a while and would run fine for a while again. Turned out to be a ladybug getting into the tank outlet and partly blocking it.
