| This is a self contained install, does not connect into the tractor CAN Bus. The harness that I have goes to the battery, to the round 3 pin accressory power in the cab, to the Pro600, and out the back to the ISOBus connector.
Where would I check on the planter ECM for power, as there is a whole bunch of connectors back there on the planter? Later today I will be able to have the tractor hooked up to the planter and trouble shoot some more, since the tractor is being used for other things right now.
Thanks everyone! | |
