Manitoba, Canada | if its still factory default settings in the antenna it should be pulling down 138. heres how to check on a pro600
- go to Diagnostics > GPS > one of the boxes should be DGPS SNR i think it will tell you what one you are set on. if not...
- go to Diagnostics > RDI > should bring up the AgRemote page. On this page it will tell you how many sats you have and what correction one it is picking up. If its reading 135 you can change it by...Press the Right arrow twice should take you to Configuration, press down once, press Right once to DGPS Config, press down until you get to a menu that says SBAS Sats i think. in that list you can edit the config to disable all the correction stats except 138. | |
