| we also have the same issue with useing slingshot.what i have done so far is put the fm back into ver 2.0.now the d port setting should stay but you may have to go into reciever change it to wass,then go into your job,then go back in to reciever and change wass to rtk and hit the ok button on the right hand bottom corner as fast as you can then it should go into rtk float then into lock and you will be ok till you power off the fm again.it,s the only way i have got it to work with the slingshot so far.hope this helps! | |
