Posted 5/25/2010 10:19 (#1213267 - in reply to #1213204) Subject: Re: Advise Convert grain cart to hyd drive?
Wheatley, Arkansas
Our experience has been that a hyd. drive cart will unload as fast as a PTO cart when running the tractor around 12-1300 RPM. If you're going to run the tractor at 18-2200 RPM the PTO would be faster. I don't see where high moisture corn would present any issues.
The Brent cart should have the mounting base in place for a hyd. motor to mount in the area of the rear u-joint on the PTO driveshaft.
