Posted 5/23/2010 20:11 (#1211356 - in reply to #1211317) Subject: Re: '97 Powerstroke chugging excessively
mw
Make sure the your oil level isnt low, I believe on the 97s the HPOP oil is also your engine oil but im not positive so it could have a separate oil reservoir, if thats the case you should check that. If your injectors dont have oil they wont be able to fire. Pretty common.
