nebfarmer - 5/23/2010 15:24 How can I clean up the active posts file. Lots of minr have been dead for a long time and they sure slow down the checking process If I recall correctly, the software is set to display your active threads for the last 30 days; I do not believe the admins have an option to change that without a code hack. BUT, if you want to hack that url it is simple. If you look at the url of the "Your active threads" you will see that the url ends with "&days=30". Simply change the 30 to the number of days that fits your pleasure. If you want to revisited that same url/query and you do not wish to hack the url each time, make/identify an entry in your Favorites. |
