franksville wi | those are the settings i have in i have also tried 5hz and 10hz. put 19k2 in both and 38k4 in both and tried I TSIP 38K4 8N1 NMEA 19K2 also all with 5hz and 10hz. Just updated the intellislope to the newest upgrade and now in the grade control screen it does say GPS @ 1 hz and flickers to No GPS back and forth. I know I am probably missing something easy but it is set on hp/RTK not jd also and only GGA mesages is in caps. is there somewhere else in the ag remote that i am missing a place to change the hz other then in GPS configuration. Does the port output have to be turned up my is at NEMA out 1s TSIP out ASAP.
Edited by garywi 5/22/2010 16:58
