Posted 5/24/2010 21:06 (#1212614 - in reply to #1209469) Subject: Re: I need a GPS GURU!!!!!!
Australia
If they have all moved by a set amount, can't you use a field offset to correct them all? Most systems have this feature, so if you were able to sit on top of your original line and it tells you how far off you are, you should be able to enter this as a field offset and be back on your lines.
