| If the RTK base is set for Quick Survey Base Mode you will need to shift track if returning to use a previous A/B line. The RTK base must use Absolute Survey Base Mode for repeatabilty. It requires a 24 hour position survey before it will transmit corrections. It needs to be in this mode if you need repeatability.
Maybe the dealer has the base station in the quick survey mode?
Edited by GPSNUT 5/24/2010 06:11
