Strasburg North Dakota | I have a John Deere 140 lawn mower with a kohler L321 14hp engine. The engine ran good until i decided to overhaul the engine. I installed a new piston and rings. Now the engine misses terribly from mid throttle to high throttle. At low rpms it seems to run good. I have cleaned the carb, changed the points, changed the coil and I am out of ideas. Has anyone else had this problem on a kohler or does anyone know what I should check next. Thanks | |
