Fruita CO | Like Gerald said, starts on vapor, go to liquid after it warms up enough to not freeze the converter. It seems like the vapor valve has an excess flow valve in it that trips if a line blows, maybe it's stuck...sounds like you're not getting enough vapor to start. Been a long time since I messed w/a LP...main thing I remember is don't wash the converter parts in the parts washer unless you're ready to change the solvent...PEEE-YEWEEE!!! | |
