S.E. Iowa | Had 40 arce piece gridded report came back showing 2.5 acres with PH of 6-7 other 38 acres was 7- 7.6 havent put lime on in the 10 years weve had the farm that I can remember. Usually SE iowa ground suffers from lack of lime, where should PH be and if too high how does one correct it. P showed a small low area with most of field being 28- 46 ppm the field was sampled before we put a 100lbs/acre of P on this spring. K ranged from 115 to as high as 259 ppm Organic matter was in the 4.3-5 range Now that I have all this info where do I go from here with it. | |
